BPMN Tutorial: Writing Working Procedures
A Business Process Diagram is an effective tool for modeling the workflow in your company or department, as it provides a clear picture of the responsible parties and the flow of the process. However, it does not specify how a particular task should be performed. With Visual Paradigm, you can define working procedures for tasks in your business process, allowing you to document how each task should be performed. This tutorial will guide you through the process of defining working procedures for your business process and generating them into a comprehensive report that can be shared with your team members.
Define Working Procedures
To define working procedures for your business tasks:
- Right-click on the blank area of your Business Process Diagram and select Show Procedure Editor.
- Select a task in your process diagram.
- Start entering the working procedures in Procedure Editor.
- You can make use of the Increase Indent button (or tab shortcut key) to create sub-steps for your working procedures.
- Once you finished entering the procedures, simply click on the blank area of the diagram to end editing or you can directly click on another task to define its procedures.
Create multiple procedures for a task
In some cases, a single procedure is insufficient to describe all possibilities for a task. In this case, you can define multiple procedures for it. To define multiple procedures for a task:
- Click on the combo box in the Procedure Editor and select Manage… to open the Procedures dialog.
- Click the New Procedure button to create a new procedure and name the procedure as you desire.
- Once the new procedure is being created, you can then follow the steps above to fill in the details.
- You may also rename your existing procedures by clicking Rename Procedure.
For tasks with multiple procedures defined, you can click on the combo box in the Procedure Editor to switch between the working procedures.
Generate Working Procedure Document
The working procedures are not just defined in the tool, you can also output them as a document and distribute it to your team. To generate a working procedure document:
- Select Tools > Doc. Composer… from the application toolbar.
- Click on Build Doc from Scratch.
- Select your Business Process Diagram in the Diagram Navigator and then drag it onto the document editor. You should see the BPD appear in the document.
- Expand the diagram node in Diagram Navigator to select the task or tasks that have working procedures defined.
- Select the Details template and drag it onto the document editor, below the BPD. You should see the procedures of your tasks listed in the document.
- Click on the Export button at top right corner of Doc. Composer and pick the format you like to export. i.e. PDF Document this time.
- Enter the location where you would like to output your working procedure document.
- Optionally enter the cover page details for your document.
- Click Export to generate a document once you have finished entering the details for the document. The working procedure document is now being generated to the location where you have specified. Then, you can distribute it to your teammates.
What this Tutorial on YouTube
Here is the video version of this tutorial.
